Jira Query Language (JQL): Advance search "WHERE" statement in JQL?
starryeyes
My team is trying to resolve an issue to help find cross functional dependencies where the team is dependent on a task that is involved in another project. The issue here is dependencies track in different projects are not visible in the corresponding team's scrum board.
To the resolve the problem, the team's are required to linked the impacted issues to the related stories or epics. A dashboard will pull that information to display intra and inter project dependencies base on the query to pull related links where the related link is not equal to the Project
Proposed Query:
(project in ("PROJECT A", PROJECT B, PROJECT C ) AND issuetype in (Story, bug, Sub-task) AND (issueFunction in hasLinks("blocks") OR issueFunction in hasLinks("is depended on by")) and status != Closed) WHERE issuefunction in hasLinks != (project in ("PROJECT A", PROJECT B, PROJECT C )
To my knowledge, JQL does not have a WHERE clause. What would be the best approach to resolve this problem?
Payne
February 18, 2020
The entire JQL clause is the where clause. Simply add another AND to your proposed query, instead of a WHERE. Think of WHERE as being at the beginning of it all.
starryeyes
I am trying build a query to that will pull intra related dependencies across different the projects. Ideally, the search return from project A where at least one of the issue keys in the related links does not share the same project key prefix as Project A.
Proposed Query:
(project in ("PROJECT A") AND issuetype in (Story, bug, Sub-task) AND (issueFunction in hasLinks("blocks") OR issueFunction in hasLinks("is depended on by")) and status != Closed) WHERE issuefunction in hasLinks != (project in ("PROJECT A", PROJECT B, PROJECT C )
Base on your explanation, the query to follow
(project in ("PROJECT A") AND issuetype in (Story, bug, Sub-task) AND (issueFunction in hasLinks("blocks") OR issueFunction in hasLinks("is depended on by")) and status != Closed) AND issuekey in hasLinks != (project in ("PROJECT A", PROJECT B, PROJECT C )
Like Deleted user likes this
sukkeong
February 17, 2020 edited
You can try creating a filter for the main query and call it in the current query,
filter = "my-other-filter" AND <more filtering>
It functions by taking the result of the saved filter and apply further filtering on that result.
Hope this helps...
starryeyes
Is there a statement where I can filter the related links based on the project key prefix?
In this case, I would want to bring related links in project A, but only return related links that do not share project A prefix.
sukkeong
February 25, 2020
I don't think you can search on key prefixes.
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
