×Hey,
I got a problem with Jira and link it to Confluence using Applicaion link, main problem could be SSL certificate what is inject using apache. Thanks in advice for all hint
Catalina Log:
2017-07-13 16:16:14,155 http-nio-8080-exec-2 ERROR user_name 976x20x1 n9r5jf 83.26.231.205,1.1.1.1 /secure/Dashboard.jspa [c.a.g.r.internal.http.HttpClientFetcher] Unable to perform a request to: https://jira.example.com/rest/gadgets/1.0/g/messagebundle/und/gadget.common%2Cgadget.activity.stream%2Cstreams.comment.action%2Cstream.error.unexpected%2Cstreams.jira.action%2Ccommon.date.relative
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2017-07-13 16:16:14,340 http-nio-8080-exec-2 ERROR user_name 976x20x1 n9r5jf 83.26.231.205,1.1.1.1 /secure/Dashboard.jspa [c.a.g.r.internal.http.HttpClientFetcher] Unable to perform a request to: https://jira.example.com/rest/gadgets/1.0/g/messagebundle/und/gadget.common%2Cgadget.activity.stream%2Cstreams.comment.action%2Cstream.error.unexpected%2Cstreams.jira.action%2Ccommon.date.relative
2017-07-13 16:16:14,381 http-nio-8080-exec-2 ERROR user_name 976x20x1 n9r5jf 83.26.231.205,1.1.1.1 /secure/Dashboard.jspa [c.a.g.r.internal.http.HttpClientFetcher] Unable to perform a request to: https://jira.example.com/rest/gadgets/1.0/g/messagebundle/en_US/gadget.common%2Cgadget.activity.stream%2Cstreams.comment.action%2Cstream.error.unexpected%2Cstreams.jira.action%2Ccommon.date.relative
Server.xml :
<Service name="Catalina">
<Connector port="8080"
maxThreads="150"
minSpareThreads="25"
connectionTimeout="20000"
enableLookups="false"
maxHttpHeaderSize="8192"
protocol="HTTP/1.1"
useBodyEncodingForURI="true"
redirectPort="8443"
acceptCount="100"
disableUploadTimeout="true"
proxyName="jira.example.com"
proxyPort="443"
bindOnInit="false"
scheme="https"
secure="true"/>
setenv.sh :
JVM_MINIMUM_MEMORY="1024m"
JVM_MAXIMUM_MEMORY="1024m"
JVM_REQUIRED_ARGS='-Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory'
JAVA_OPTS="-Djavax.net.ssl.keyStore=/etc/ssl/example.p12 -Djavax.net.ssl.keyStorePassword=changeit -Xms${JVM_MINIMUM_MEMORY} -Xmx${JVM_MAXIMUM_MEMORY} ${JAVA_OPTS} ${JVM_REQUIRED_ARGS} ${DISABLE_NOTIFICATIONS} ${JVM_SUPPORT_RECOMMENDED_ARGS} ${JVM_EXTRA_ARGS} ${JIRA_HOME_MINUSD} ${START_JIRA_JAVA_OPTS}"
export JAVA_OPTS
Apache config file
<VirtualHost jira.example.com:443>
ServerName www.jira.example.com
ServerAlias jira.example.com
DocumentRoot /opt/atlassian/jira
ErrorLog /var/www/jira.example.com/error.log
CustomLog /var/www/jira.example.com/requests.log combined
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
ProxyRequests Off
ProxyPreserveHost On
SSLProxyEngine On
SSLEngine on
SSLCertificateFile /etc/ssl/example.crt
SSLCertificateKeyFile /etc/ssl/example.key
ProxyPass / http://jira.example.com:8080/
ProxyPassReverse / http://jira.example.com:8080/
</VirtualHost>
<VirtualHost jira.example.com:80>
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
ProxyRequests Off
</VirtualHost>
Jira Version 7.4.0
One issue i noticed is that you should not have the Proxy configuration on both the port 443 and port 80 virtual hosts. It should only be on the port 443 virtual host.
All the port 80 virtual host should do is rewrite (forward) users to the 443 host. For instance:
<VirtualHost *:80>
RewriteEngine On
RewriteRule (.*) https://jira.example.com%{REQUEST_URI} [NE]
</VirtualHost>
You must also set your JIRA base url to https://jira.example.com
Also, since that's the JIRA log, it means that JIRA cannot verify the certificate used with Confluence. The issue may lie in your Confluence configuration. Are you using self signed or CA trusted certs?
Thanks for your reply, the main problem was with the CA certificate and protocol what Jira used I will update new config file for future knowloage
BR
