Hi Team,
We would like to integrate Jira Customer account authentication with Azure AD SSO. Please help us implement the same for our Jira account.
Wilfred JJ
Hi @IT Support ,
You should take a good look at this blog post from Rodney (aka The Jira Guy): https://thejiraguy.com/2020/06/24/atlassian-cloud-with-azure-ad/
Hello @IT Support
I work for Exalate.
Integrating Jira with Azure AD SSO is a great way to streamline authentication for customer accounts. Atlassian Access can help with this by supporting SAML-based SSO with Azure AD. You can find more details in the Atlassian Access documentation.
If your integration also involves syncing or sharing data with other systems like Jira instances or Azure DevOps, a tool like Exalate could help ensure smooth, controlled synchronization alongside the SSO setup.
Thank you.
Mathieu Lepoutre
Hi there,
An additional note is that, for connecting IdP and setting up SSO, you will need Atlassian Guard Standard or Premium. Here are some materials that might be helpful:
Along with that, the blog from The Jira Guy provides good step-by-step screenshots for configuring everything on Entra ID/AD side.
Apart from using native configuration from Atlassian Guard, you could explore Atlassian Marketplace for SSO setup and configuration.
Tom
