Sign up Log in
Jira Server Failed Startup Due to OSGI Error
alexlwilson
September 22, 2021 edited
Running Jira 8.0.0, after rebooting our Linux server today, Jira subsequently failed to start. Looking at the atlassian-jira.log shows the following -
2021-09-22 18:44:08,088 JIRA-Bootstrap ERROR [c.a.event.internal.AsynchronousAbleEventDispatcher] There was an exception thrown trying to dispatch even$
java.lang.RuntimeException: Listener: com.atlassian.jira.plugin.JiraOsgiContainerManager event: com.atlassian.plugin.event.events.PluginFrameworkStartingEve$
at com.atlassian.event.internal.SingleParameterMethodListenerInvoker.invoke(SingleParameterMethodListenerInvoker.java:50)
at com.atlassian.event.internal.AsynchronousAbleEventDispatcher.lambda$null$0(AsynchronousAbleEventDispatcher.java:37)
at com.atlassian.event.internal.AsynchronousAbleEventDispatcher.dispatch(AsynchronousAbleEventDispatcher.java:85)
at com.atlassian.event.internal.EventPublisherImpl.invokeListeners(EventPublisherImpl.java:200)
at com.atlassian.event.internal.EventPublisherImpl.publish(EventPublisherImpl.java:115)
at com.atlassian.plugin.event.impl.DefaultPluginEventManager.broadcast(DefaultPluginEventManager.java:92)
at com.atlassian.plugin.manager.DefaultPluginManager.broadcastIgnoreError(DefaultPluginManager.java:1872)
at com.atlassian.plugin.manager.DefaultPluginManager.earlyStartup(DefaultPluginManager.java:520)
at com.atlassian.jira.plugin.JiraPluginManager.earlyStartup(JiraPluginManager.java:126)
at com.atlassian.jira.component.pico.ComponentManager$PluginSystem.earlyStartup(ComponentManager.java:669)
at com.atlassian.jira.component.pico.ComponentManager.earlyStartPluginSystem(ComponentManager.java:238)
at com.atlassian.jira.upgrade.PluginSystemLauncher.start(PluginSystemLauncher.java:45)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$postDbLaunch$2(DefaultJiraLauncher.java:143)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:301)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:196)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:135)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$start$0(DefaultJiraLauncher.java:102)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:31)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:100)
at com.atlassian.jira.startup.LauncherContextListener.initSlowStuff(LauncherContextListener.java:154)
at java.lang.Thread.run(Thread.java:748)
Caused by: io.github.lukehutch.fastclasspathscanner.ScanInterruptedException
at io.github.lukehutch.fastclasspathscanner.FastClasspathScanner.getUniqueClasspathElementURLs(FastClasspathScanner.java:1834)
at io.github.lukehutch.fastclasspathscanner.FastClasspathScanner.getUniqueClasspathElementURLs(FastClasspathScanner.java:1875)
at com.atlassian.plugin.osgi.container.felix.ExportsBuilder.getClassPathUrls(ExportsBuilder.java:282)
at com.atlassian.plugin.osgi.container.felix.ExportsBuilder.generateExports(ExportsBuilder.java:252)
at com.atlassian.plugin.osgi.container.felix.ExportsBuilder.determineExports(ExportsBuilder.java:177)
at com.atlassian.plugin.osgi.container.felix.FelixOsgiContainerManager.start(FelixOsgiContainerManager.java:238)
at com.atlassian.plugin.osgi.container.felix.FelixOsgiContainerManager.onStart(FelixOsgiContainerManager.java:200)
... 3 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.event.internal.SingleParameterMethodListenerInvoker.invoke(SingleParameterMethodListenerInvoker.java:40)
... 20 more
2021-09-22 18:44:10,264 JIRA-Bootstrap ERROR [c.a.plugin.loaders.ScanningPluginLoader] Unable to deploy plugin 'com.atlassian.activeobjects.activeobjec$
2021-09-22 18:44:10,264 JIRA-Bootstrap ERROR [c.a.plugin.loaders.ScanningPluginLoader] Because of the following exception:
java.lang.IllegalStateException: Unable to create a tracker when osgi is not running
Appreciate any help determining what is causing the error.
alexlwilson
Still haven't been able to get this Jira instance working. I've begun reloading Jira on a new server, but would still prefer to get this running again if anyone has experience troubleshooting this. I'm definitely out of my depth here and have a feeling I'm missing something "easy".
Mariano
January 27, 2025
Have you ever found an answer? Been fighthing for over a week with this. My PROD server work just fine but when I mirror all the config to a cloud server, it crashes with this error.
