When creating a new issue from Slack, is it possible to show the Team field as option to fill out?
I'm refferring to this team field
https://support.atlassian.com/atlassian-account/docs/using-atlassian-teams-in-jira-projects/
Thanks, Stephen.
Not a problem!
If this answer helped, could you accept it? That helps others know it can help them too in future :)
Ste
@Nathan Stayte if you are still looking for a solution.
I would recommend slackjira.com : Jira-2 way sync , where you can create tickets with all fields within Slack with the ability to select Team too.
In case you need more information , feel free to DM / reply
