Jira Software 7.8.1 w/Apache 2.4 Reverse Proxy Errors
Patrick Kyne March 30, 2018 edited
Environment:
  • CentOS 7.4 Server
    • Apache 2.4
      • mod_proxy
      • mod_proxy_ajp
      • mod_ssl
      • mod_rewrite
      • listen on 0.0.0.0:443
      • vhost.conf:
        • <IfDefine SSL>
          <IfDefine !NOSSL>
          <VirtualHost _default_:443>
                  # JIRA Proxy Configuration:
                  <Proxy *>
                          Require all granted
                  </Proxy>
                  SSLProxyEngine          On
                  ProxyRequests           Off
                  ProxyPreserveHost       On
                  ProxyPass               /jira       ajp://127.0.0.1:8009/jira
                  ProxyPassReverse        /jira       ajp://127.0.0.1:8009/jira
                  #  General setup for the virtual host
                  DocumentRoot "/srv/www/htdocs"
                  ServerName external_server_name.fqdn:443
                  ErrorLog /var/log/apache2/error_log
                  TransferLog /var/log/apache2/access_log
                  SSLEngine on
                  SSLCertificateFile /etc/apache2/ssl.crt/external_server_name.crt
                  SSLCertificateKeyFile /etc/apache2/ssl.key/external_server_name.key
                  CustomLog /var/log/apache2/ssl_request_log   ssl_combined
          </VirtualHost>
          </IfDefine>
          </IfDefine>
    • Atlassian Jira Software 7.8.1
      • {install directory}/conf/server.xml (comments removed for brevity):
        • <?xml version="1.0" encoding="utf-8"?>
          <Server port="8005" shutdown="SHUTDOWN">
              <Listener className="org.apache.catalina.startup.VersionLoggerListener" />
              <Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
              <Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
              <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
              <Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener" />
              <Service name="Catalina">
                  <Connector port="8009" redirectPort="8443" enableLookups="false" protocol="AJP/1.3" URIEncoding="UTF-8"/>
                  <Engine name="Catalina" defaultHost="localhost">
                      <Host name="localhost" appBase="webapps" unpackWARs="true" autoDeploy="true">
                          <Context path="/jira" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true">
                              <Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction"
                                        factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60"/>
                              <Manager pathname=""/>
                              <JarScanner scanManifest="false"/>
                          </Context>
                      </Host>
                      <Valve className="org.apache.catalina.valves.AccessLogValve"
                             pattern="%a %{jira.request.id}r %{jira.request.username}r %t &quot;%m %U%q %H&quot; %s %b %D &quot;%{Referer}i&quot; &quot;%{User-Agent}i&quot; &quot;%{jira.request.assession.id}r&quot;"/>
                  </Engine>
              </Service>
          </Server>
      • Base URL configured as: https://external_server_name.fqdn/jira
Issues:
I've reviewed all available KBs (keywords: apache, jira, confluence, ajp, reverse-proxy, etc.) and comments, but must be missing something.
Any ideas as to what I may have wrong or missing?
KellyW
April 28, 2018
Hi Patrick,
Seems like the following proxy settings are missing in the Tomcat's Connector directive. Example:
scheme="https" proxyName="<FQDN_APACHE_SERVES>" proxyPort="443"
Check out this KB -- Proxying Atlassian server applications with Apache HTTP Server
Kelly
