Jira Software - service won't start
phuddleston@library.msstate.edu
July 19, 2018
We have a locally hosted server.  It is running JIRA, JIRA service desk, confluence and BitBucket.  They are all operating on different ports.  This is a Windows 2016 Server and we are using PostGRE SQL.  It appears that bitbucket, elasticsearch for bitbucket, confluence and JIRA are all installed as a service.
Everything was working, but was slow.  Eventually, the web interface stopped responding and we could not access it.  After looking at the server, the JIRA software was using over 2 GB memory and 80% CPU of the computer.  There are 4 cores @2.6 GHZ.
We tried to stop the service, but it would not stop.  After waiting a long time, we restarted the server.  After that, only the confluence service restarted.  All of the others quickly respond saying: Atlassian JIRA service terminated with the following service-specific error: Incorrect function.  EventID:7024
The co
4 votes
Earl McCutcheon
July 20, 2018
Can you try running Jira using the bat file which is located here using command prompt -
$JIRA_INSTALL/bin/start-jira.bat
This should bypass the service and run Jira, if this starts then it could mean that the Jira service on Windows may have been corrupted and the service may need to be recreated by following the instructions here -Running Jira application as a Windows service.
If this works I would recommend the you remove the service from Windows via command prompt (run as administrator) using the command -
service.bat remove JIRA
Or if above does not work use -
tomcat8 //DS//JIRA
Then install the service again with -
service.bat install JIRA
Then try starting Jira again from the services, and let us know how it goes.
Earl
July 23, 2018
We were able to get things started with the batch files.  It seems that there was something that had happened to mess up the Java versions from what were installed compared to what was in the path.
I have not yet removed the old and installed new services.  I will report back when that is complete.
Thank you.
Paul
Like Earl McCutcheon likes this
Harikanth October 4, 2019
Earl McCutcheon,
Thanks! It's worked for me
Best Regards,
Harikanth kadhanagal
Mark Ahnell
I was getting an Error 1067: The process terminated unexpectedly when starting Atlassian Jira and the unistall and reinstall of the service worked!  Thanks!
David Oliván
December 27, 2021
When uninstallin gservice, service name could include a number, like JIRA100520103045, so the command sould be:
service.bat remove JIRA100520103045
 Same applies IMHO whe creating the service again:
service.bat install JIRA100520103045
