Jira Structure - add issue under the parent automatically on creating the issue.
Santhosh R Bhat
Hello All,
I m using Jira cloud, Structure plugin.
Structure config steps:
1. Added "Insert Generator" project name and Epics in the project.
2. Added all story in the epic.
3. Added all subtasks in the story.
4. Extended with linked issue. Provided proper link type (Implemented By and Implements).
With this setup all the existing epic, story, subtasks and linked issues got lined up in the required hierarchy.
Problem Definition:
If I select the parent issue and try to create new issue ("Add -> Create Item -> Issue" or by clicking on "Create" button) the created issue does not get linked to the parent automatically. Every time I have to manually setup the link type and add the parent issue id to which it has to be linked to.
Expected Result:
When i select any parent issue and click on "Add->Create Item->issue" then the link type and parent issue id has to be set automatically in the create issue screen.
Is there any way to achieve this or is  there any workaround. Please suggest and help
Santhosh R. Bhat
Sayed Bares _ServiceRocket_
@Santhosh R Bhat You may want to reach out to Plugin's support team to confirm whether it is a bug and if there is a workaround for it:
Help us plant more trees
