Jira Suite Utilities Options
James Wood April 21, 2015
Hi
I am creating a workflow in my new JIRA instance, based on an existing work flow in a previous set up.
In both, I am using JIRA Suite Utilities 1.4.9, but there are some options which aren't available in the new instance, such as the validator INCREASE VALUE FIELD.
Am I missing something?
James
Nic Brough -Adaptavist-
April 22, 2015
"increase value field" is not a JIRA Suite Utilities function (and it's a post-function, not a validator - you don't change data in validators).  I suspect you're missing one of the other utilities (Misc workflow extensions?)
Register now
