Jira Swimlanes Disappeared?
Mary from Planyway
I noticed that now I can not create Swimlanes trough Board Settings. Does it the same for you? Now, there is only the option for columns. Is there a way to return them back? What concerns me is Jira documentation which still has the article on Jira swimlanes set the old way. Please help!
2 accepted
3 votes
Tuncay Senturk
November 1, 2024 edited
Hi @Mary from Planyway
Swimlane configuration options can differ between project types. If you're using a Team-Managed project, some advanced board settings like swimlanes might not be available or are configured differently compared to Company-Managed projects.
You can vote/watch this ticket.
Mary from Planyway
Thank you!
Tuncay Senturk
You're welcome! I hope it helps
Tomislav Tobijas
Hi @Mary from Planyway ,
Another thing worth mentioning here (at least it enlightened me when I was preparing for one exam) is that swimlanes are casually being 'replaced' by Group by feature directly on the board view.
Although I've checked a couple of instances we manage and in each, there's still Swimlanes tab under board settings (if we're talking about company-managed projects).
Tom
Fabian Marx
November 11, 2024
If you want to use queries, it seems you need to configure them in the old swimlane tab. Then you can use them with the group by filter.
Marc - Devoteam
November 2, 2024
As @Tomislav Tobijas mentions, this is happening.
I noticed when using this "new" feature on the board, the swim lane function in the board config will not work anymore.
The only solution then is to create a new board, swiml anes will work, until anyone with access to the board uses the group by function, then the same issue is back.
