i have a .csv file which im importing into Jira Xray via "Testcase Importer". This works fine.
The bad thing is: i have to create manually a Test Execution for each imported Test.
isnt there a way, so that if I import 10 Testcases, that it will automatically also create 10 Test Executions (which are not run yet)? 1 Test Execution for each Test.
Is this possible?
OR:
create 1 test execution automatically and add all 10 tests (or 1 testset with these 10tests) to this test execution.
Hi @[deleted]
Automatically from the Test Case Importer, it is not possible.
If you need additional help, please contact the Xray Support (http://xraysupport.xpand-it.com ) so that we can request additional information and help further.
Rogério Paiva [Xray Support Team]
