Jira automation for update components from custom field
aviv_eldad
Hello everyone,
I have a multi-select list custom field "A". All the values in "A" are also components in the project (for example, for value "b" I have "b" component).
What I am trying to do is that when field A is updated (values added/ removed) on an issue, update the component field with the same values on this issue.
I tried a lot of smart values and options I found on the web, but none of them gave me what I needed. Is this thing possible?
I'll really appreciate your help.
Thank you!
aviv_eldad
So I asked Atlassian and they gave me the answer. You need to do the following smart value:
"update": {
"components": [ {{#issue.A}}{{^last}} {
"add": {"name": "{{value}}"}
"add": {"name": "{{issue.A.last.value}}"}
Let's build A Rovo Agent 🤖
Save your spot
