Jira automation success but Sprint field not set as set
Carolina SILVA
February 21, 2022 edited
hi all,
I created an automation rule when a Sprint is created, I want a Story to be created + 2  fields set (Description + Sprint)
the rule is successful but Sprint field is not set.
February 23, 2022
Hi @Carolina SILVA
Please try setting the sprint to the one that triggered the rule using {{sprint.id}}
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/#--Sprint--
Carolina SILVA
February 24, 2022
hello @Bill Sheboy  can you please add a screenshot?
February 24, 2022 edited
Hi, Carolina.
Please try entering that smart value for the Sprint field when creating the issue.  The value will appear below the field, so you need to select it for the smart value to be used.
Carolina SILVA
February 24, 2022
hello @Bill Sheboy  I'm blocked by this error message
Carolina SILVA
February 24, 2022
February 24, 2022
That error is because the trigger is for a sprint, and you are trying to edit an issue (story), so the rule doesn't know what the "current" issue is.
Please try to set the sprint field when you create the story.  That will do this in one step.
The other way to solve this error is to add a branch on the most recently created issue after the create and before you perform the edit.
Aditya Sastry
February 21, 2022
Hi Silva,
The sprint value is not set as it is a future sprint and isn't active yet.
Aditya
Carolina SILVA
February 23, 2022
Hello @Aditya Sastry
thanks for your reply, but it does not help. Maybe I did not explain well.
When I create my automation, It's to plan a Story creation each time I create a new sprint.
So I create the sprint -> automation creates the Story -> I expect the sprint I created to be set on my Sprint field.
Can you please help?
thanks
Caro
