Jira automation
Rajan Dangol
I am getting the following error within sub tasks automation "Destination status could not be resolved. If using a smart-value ensure this resolves to a numeric status ID or untranslated name for issues (with current status)". However, the email is sent.
Automation requirement:
1) Sub tasks is created.
2) When value changes for assignee
3) Issue type equals sub- task.
4) Then transition the issue to Pending.
5) Then send email.
I think the issue is failing because the issue is reassigned after being assigned the first time.
Hans Polder _Devoteam_
@Rajan Dangol ,
Generally speaking, the error message states that the status 'Pending' does not exist in the workflow for the issue (type) in question.
Can you paste a screenshot of the workflow that is assigned to Sub-tasks in this project?
Rajan Dangol
Like Olena Tsarova_TitanApps likes this
Rajan Dangol
I think the initial ticket has been assigned, the ticket is changed to Pending and then when it reassigned the ticket is already in Pending, hence the error. I think.
Could it be that the affected issue was already in status Done, hence it couldn't go to 'Pending'?
Ah, that could also be the case, indeed! Simply resolve that by adding a condition at the start 'status is not Pending', then it will not trigger on those!
Rajan Dangol
Looking good! 😊
Like John Funk likes this
Rajan Dangol
Thanks Hans, appreciate your quick response :)
Like # people like this
Rajan Dangol
