×On starting an import of Jira data from another instance I get message as shown below.
What Jira version is build 77002? Atlassian of course publishes Jira version and build numbers but this particular build number 77002 is not on that list.
You can find the build versions for various JIRA versions here
I suspect that the version in question may be a JIRA 7.7 but I cannot tell from the build version if this is 7.7.0 or 7.7.2 (this depends on minor fix version).
However, as the versions are mostly similar, I would suggest getting any JIRA 7.7 and it should work just fine.
Cheers.
