Hello
Have you tried using below API
https://your-instance.atlassian.net//rest/api/3/users
This gives a paginated response. So, if you have more than 1000 users, then you will have to make additional API calls
this is not what I'm looking for - all users are returned. I need users of particular product
In the first sentence it was mentioned particular site so I thought you have multiple sites.
Can you elaborate with an example what particular product are your referring to?
is it like JSM, JIRA, confluence etc.?
I have one organization and within it I have:
- siteY:
* jira
* confluence
- siteX:
* jira
* confluence
I need endpoint which will return users of siteX jira.
To access siteY and siteX, do you navigate to below your URL to access
I could find endpoints that gets users in an organization. However, I couldn't find any endpoints that give site specific details.
what am I supposed to do? I need to retrieve users (or number of users) that are counted for charging by atlassian
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
