We use Jira Cloud version.
I would like reopen a completed sprint. In the Jira documentation I can see that you can reopen a sprint in Jira cloud as follows :
However, when I perform step 1,2 and 3 then I do not see 'Sprint Report'.
I only see
Can you tell me (step by step) how to access 'Sprint Report' so that I can reopen completed sprints?
Thank you,
Peter
Ahh - is this a Next Gen project? Apologies, we should have worked that out upfront!
Unfortunately you cannot re-open a sprint in Next Gen at this stage - you can vote for the inclusion of this feature though here: https://jira.atlassian.com/browse/JSWCLOUD-17208
Ste
Hi @andrés
Next-Gen is separate to Classic so it's not designed to completely replicate it. It's being built from the ground-up so you will see a variance in some features.
If you want this feature you can still use Classic. If not, then it'll be dependant on what features Atlassian choose as priority.
Bear in mind reopening a sprint hasn't been around since the beginning of Jira Cloud - see JSWCLOUD-7804 for its release back in 2016.
Ste
I don't why Jira does not make this basic feature becoming available. It's a shame.
@Ste Wright
I guess my question to Jira is Why would this NOT be considered as a feature in Next Generation Jira Project? AKA how does this benefit or how is removing this an improvement on old functionality?
You can enable the releases section and see the Version created for that sprint and that is about it.
I accidentally closed the wrong sprint and now I am left having to just re-create another one and loose all my metrics.
Via the view in printscreen above, I select IELP Board then I am already in the board
or I select IT e-llis Projects (IELP) and then select the Board.
From then I select Reports and then I see
only see
But I do not see Sprint Reports
Have you tried going to the Board rather than the Project? If your Board is multi-project it might now show up on each project in itself.
Try instead:
Let us know how this goes :)
Ste
Thank you for your feedback.
What exactly do you mean with 'Board'?
When I select Dashboard, I see following options :
You want to go to the main board for your sprint - which will be attached to one Jira project in Cloud.
To locate the Board:
Ste
When I select the Board of my project and then select
3. Reports
I only see
I do not see 'Sprint Report' (see attachment)
Thanks for screenshot below - are you sure you're locating the board? There's no board mentioned below - you're in the project's reports.
Usually the board will appear with its name, the backlog, active sprint board, etc - the same location you sprint plan and activate sprints.
Did you follow the instructions above for locating the board via search rather than via the project view?
Ste
