Jira error on loading
Martin Schwartzman July 7, 2014
Hi, my name is martin and im using jira agile. My installation was fine, the team was uploading all kind of project and issues. When the server administrator installs Microsoft SQL Server 2088 R2 Service Pack 2 i get the "JIRA Startup Failed" Error when i came into my Jira site.
The full error is:
JIRA Startup Failed
The following plugins are required by JIRA, but have not been started:
  • JIRA Project Config Plugin (com.atlassian.jira.jira-project-config-plugin)
  • Embedded Gadgets Plugin (com.atlassian.gadgets.embedded)
  • Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard)
  • Atlassian REST - Module Types (com.atlassian.plugins.rest.atlassian-rest-module)
  • Atlassian JIRA - Plugins - REST Plugin (com.atlassian.jira.rest)
  • Atlassian OAuth Service Provider Plugin (com.atlassian.oauth.serviceprovider)
  • Atlassian OAuth Consumer Plugin (com.atlassian.oauth.consumer)
  • Opensocial Plugin (com.atlassian.gadgets.opensocial)
  • Gadget Directory Plugin (com.atlassian.gadgets.directory)
  • Atlassian Navigation Links Plugin (com.atlassian.plugins.atlassian-nav-links-plugin)
  • Applinks Product Plugin (com.atlassian.applinks.applinks-plugin)
  • Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
  • Atlassian JIRA - Plugins - Quick Edit Plugin (com.atlassian.jira.jira-quick-edit-plugin)
  • Atlassian JIRA - Plugins - Issue Search (com.atlassian.jira.jira-issue-nav-plugin)
I need a response as soon as posible, because im tryng to get the real version instead the trial but i need high availability of the service.
Thanks for all.
Martin Schwartzman July 13, 2014
Finally, we uninstall TFS 2012 express and jira seems to work fine again . It was quite unusual, but after all jira is working. Thanks to all for your responses, i will return in a few months when im going to need to install TFS again.
Nic Brough -Adaptavist-
July 7, 2014
No easy way to tell what it is, but work your way through https://confluence.atlassian.com/display/JIRAKB/Troubleshooting+JIRA+Startup+Failed+Error
July 7, 2014
6000 seconds to load is total overkill (but I completely understand why you've done it, and it's a useful test)
I think there's something else going on here - could you take a look at how much cpu it's using?
Hello again Nic,
The Server Admin told me that both the CPU and memory are within normal values. He realize the test while jira service was starting and also when the first user try to get in into the jira site.
I think im gonna uninstall TFS and microsoft sql server 2008 r2 SP2, and jira will work fine again.
Thanks again for your response
