Jira fail over configuration
Hyd3k
Hi community, do you have any recommendation and tutorial for configuring Jira software with fail over for linux? Maybe Pacemaker? Any other third party?
Will
2 accepted
Orawan Sittakom
June 11, 2018
Hi @Hyd3k
I can share you my experience to do JIRA failover on linux roughly.
  • We setup JIRA on different locations, the primary is on and secondary is off.
  • We set DataGuard for DB data synchronisation (real-time). So data in both servers will be always the same.
  • We set Rsync (every 15 mins) for data file replication (<JIRA_HOME>/data/).
  • When JIRA failover is required, primary server will be stopped and start JIRA service in secondary server and then re-indexing is required on secondary server.
Michael Simon
September 13, 2018
@Hyd3k
So data is the only required dir under jirahome?  Not plugins, caches (maybe that is the re-indexing that happens).  What about license file like mentioned in dbconfig.xml?  This might end up being more simple than expected.
Thank you for the great details.  We already had the DB replication setup and were trying to determine if sync'n the jirahome (was going to entire dir) would be OK or if there were other issues that would come up along the way.
MoroSystems Support
June 11, 2018
Hyd3k
Thanks for the reply, you are a ninja.
Register now
