I am looking for a way to show Jira issues in a calendar. I need to be able to edit their dates by moving them to another day in the calendar.
There are a few addons in the Jira Marketplace that can do this, however I would like to use a universal calendar, the type that can display several together (like work, personal/private and Jira). So a calendar view within Jira is not what I mean.
An example is the standard iOS iPhone calendar. How do I display my Jjira issues there (and still be able to move them to other dates)?
The plugin I found that comes close is
But this is quite limited. I had a few technical problems with it at first, which prevented the issues to show in my calendar. The greatest disadvantage was the fact that I could not pick my own date field but had to use a fixed one, specially made for this plugin.
This is not possible as of now. You can only use few addons avaialble in Atlassian marketplace which can address a part of your need (but wont meet your needs completely)
Hi Tim,
As I know there are special PlugIns for this.
You cannot include tickets in your daily callendar and also if you will move the from calendar to be atomatic change the dates in Jira.
