Jira issues in many Sprints
Arensa Prasta
Is there a way in Jira to detect issues that are going from one Sprint to another?
More precisely I would like to list all issues that have been unresolved but still present in two or more Sprints.
Laurie Sciutti
Hi @Arensa Prasta ~ maybe this can help?
Arensa Prasta
Thank you so much @Laurie Sciutti
Like • Laurie Sciutti likes this
Hannes Obweger - JXL for Jira
Hi @Arensa Prasta
if you prefer a solution that doesn't require scripting or advanced JQL, you may want to have a look at the app that my team and I are working on, JXL for Jira
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of so-called smart columns that aren’t natively available, including the number of sprints (along with many other sprint-related columns).
This is how it looks in action:
As you can see above, you can easily sort and filter by the number of sprints, and also use it across JXL's advanced features, such as support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting.
This all just works, so there's no scripting or automation whatsoever required.
Any questions just let me know
Best,
Hannes
