There's an active incident that's impacting the sync between Jira and the integrated development tools. It's impacting only a few customers.
You may raise a support ticket so our teams will keep you updated about the progress on this.
Losing connection between Jira and Bitbucket can be frustrating, but there are a few common things to check that often help:
It’s helpful to have an integration setup that automatically retries and recovers from these hiccups, so you don’t have to manually fix things each time. You may want to explore OpsHub Integration Manager (OIM), an enterprise – grade integration solution and an Atlassian Partner that automatically retries failed syncs and handles errors, saving a lot of headaches when connections drop. your tools stay connected and data stays aligned with less manual intervention. Bidirectional, deep data sync - all this without writing a single line of code
Hope this helps! Feel free to ask questions or request a demo if you want to go deeper on any of these points!:)
Hello @Andreas Gade Hjarnø
Could you specify more regarding the lost connection:
Hi @Andreas Gade Hjarnø ,
first of all please check integration between JIRA and bitbucket (https://support.atlassian.com/bitbucket-cloud/docs/connect-bitbucket-cloud-to-jira-software-cloud/)
Moreover, please verify that you have access to repo linked to your jira ticket.
Let us know,
Fabio
