Jira multi-level custom field
Aleks Vujic
January 28, 2025
Description
We would like to support the following custom field inputs.
  1. Each issue can have n configurations (dropdown of predefined strings).
  2. Each configuration can have n tests (dropdown of predefined strings)
Example
Issue IS-1234 has 3 configurations. Each configuration has some affected tests.
  1. Configuration: "intel-i5", tests: [ "trace", "debug" ]
  2. Configuration: "intel-i7", tests: [ "trace", "profiler", "coverage" ]
  3. Configuration: "ryzen-7", tests: [ "coverage" ]
Can this be implemented in Jira without any plugins? If not, are there any plugins which support this functionality?
Dick
January 28, 2025
Hi @Aleks Vujic Welcome to the Atlassian Community,
What you need is a working multi-level-dropdown-form/qaq-p/2176799 described by @Walter Buggenhout
Go from his fine post and if things do not work out for you, you can always put a specific follow-up question here.
Dick
