Hi, So I made a service account to call Jira's API's and it is not returning all the projects available on jira. I used the API token method to authenticate and gave all the required scopes for reading projects, users. Is there any setting to add a service account or a user account on to each of the project separately. Please clarify this asap, Thanks in advance!
Welcome to the community :)
As per what Karan mentioned, the same API call should help. Could you also check if service account has browse project permission to all the projects
Could be the reason that its not returning all projects.
Thank You,
Prachi
Hey @Neha Kantheti
If the scopes are configured correctly, it is likely that the endpoint you're using is incorrect. With scoped API tokens, the URL format is {{https://api.atlassian.com/ex/jira/{cloudId}}
Please check this document for details and verify that you're using the correct format: https://support.atlassian.com/atlassian-account/docs/manage-api-tokens-for-your-atlassian-account/
Yes, I'm using the same endpoint with cloudId, even then it is only returning some projects.
