Jira scriptrunner email template not adding line breaks.
Shawn Mahoney April 1, 2019
How can you add a new line within this example?  Regardless of how I do this, the email is sent with everything on the same line.
def fields = get('/rest/api/2/field')
.asObject(List)
.body as List<Map>
def customFieldId = fields.find { it.name == 'TextFieldB' }.id as String
def customFieldValue = (issue.fields[customFieldId] as Map)?.value
"""Dear ${issue.fields.assignee?.displayName},
The ${issue.fields.issuetype.name} ${issue.key} with priority ${issue.fields.priority?.name} has been assigned to you.
Description: ${issue.fields.description}
Custom field value: ${customFieldValue}
${issue.fields.reporter?.displayName}"""
Payne
April 1, 2019
Perhaps you have Email format set to HTML, in which case you need <br> or <p> tags to cause linefeeds, e.g.
<p>Dear ${issue.fields.assignee?.displayName},</p>
<p>The ${issue.fields.issuetype.name} ${issue.key} with priority ${issue.fields.priority?.name} has been assigned to you.</p>
Either do that or switch from HTML mode to Plain Text mode.
Thanks,  I figured this might have something to do with it, but the script console made it look like the tags would be included as literal strings in the return.
Register today
