Jira service desk integration with jira software
Shrikant Maheshwari May 22, 2018
how can we integrate JIRA Service desk with Jira software?
Is it possible without without use of plugins?
Nic Brough -Adaptavist-
May 22, 2018
Install both on the same Jira Core server (or add one to an installation of the other), via Manage Applications.  They "integrate" automatically then.
Of course, there's a massive question here though - what do you want from "integration"?
@Nic Brough -Adaptavist-
Both are the cloud versions.
May 22, 2018
Your best option is to shut down one of the instances and enable the application on the other one
Kris G _Alacriz_
May 24, 2018
If you are talking about Atlassian cloud, don't worry. Atlassian will take care of the integration.
If your question is about a third party cloud service, you'd install JSD along with Jira Software, use the same port during installation and they are integrated automatically.  No plugins or applications are required.
While doing JSD installation after Jira Software installation, if you specify different ports for both, they'd be different instances on the same server and hence not integrated.
I hope that helps.
Best,
Kris
Adrián Plaza [DEISER]
May 22, 2018
Hi @Shrikant Maheshwari,
Both applications are natively integrated you only need to install both on the same server.
What application you have nowadays?
Adrián.
Currently we are using JIRA cloud at one isntance and Jira Service desk at other instance
@Adrián Plaza [DEISER]
We are currently using Cloud version of both JIRA as well as Jira service desk
May 22, 2018
You need to put both applications in the same Cloud instance, is this possible for you?
Adrián.
Shrikant Maheshwari May 23, 2018
So if both the applications are in the same cloud instance, they will integrate aumatically or we need to do something.
May 23, 2018 edited
It depends on what kind of integration you want, by default you have this: https://www.youtube.com/watch?v=6Cl8qbSIwqE
Adrián.
Thanks for the reply we just need to flow some information from JIRA Service desk to JIRA.
My query is if both the applications are on the same cloud instance, how they would integrate.Do we need to configure application link or install some plug-in
May 23, 2018
No, you don't need to install anything the APP's are totally integrated by default.
Adrián.
