Jira software 8.17 has jdk vulnerabilities
jy August 3, 2021 edited
I have tried before using the rpm jdk to run jira application, it does not work, as some inbuilt path uses the jira jdk path to run.
Currently our Nessus software has detected 1 high, 2 medium vulnerabilities related to jre.
High -Oracle Java SE 1.7.0_311 / 1.8.0_301 / 1.11.0_12 / 1.16.0_2 Multiple Vulnerabilities
The following vulnerable instance of Java is installed on the
remote host :
Path : /opt/atlassian/jira
Installed version : 1.8.0_275
Fixed version : 1.7.0_311 / 1.8.0_301 / 1.11.0_12 / 1.16.0_2
Medium-Oracle Java SE 1.7.0_291 / 1.8.0_281 / 1.11.0_10 / 1.15.0_2 Information Disclosure
remote host :
Fixed version : 1.7.0_291 / 1.8.0_281 / 1.11.0_10 / 1.15.0_2
Oracle Java SE 1.7.0_301 / 1.8.0_291 / 1.11.0_11 / 1.16.0_1 Multiple Vulnerabilities (Unix Apr
2021 CPU)
remote host :
Fixed version : 1.7.0_301 / 1.8.0_291 / 1.11.0_11 / 1.16.0_1
May I know how to update this jre?
Andy Heinzer
August 4, 2021
Hi @jy
We have ticket that tracks the update of the bundled Java that is include in Jira Server/Data Center editions.  The most recent of which is JRASERVER-72515.  Updating Jira to 8.18.1 will update the bundled Java to 8u292, which will address at least the two medium vulns listed there.
However the version bundled does not appear to address the other vuln you mentioned.  In which case, you can install your own version of Java and then tell Jira to use that version.  Steps to do this are in Jira Server: Installing Java.  Once your updated version is installed on your operating system, you will need to set the JAVA_HOME variable in your environment.  That document also has steps on how to do that for various environments.  After that is set, you will then need to start or restart Jira to get it to start using that updated jre/jdk environment.
I hope that helps.
Andy
jy August 5, 2021
I have tried with the second solution, install own openjdk rpm then set the JAVA_HOME to point to the openjdk java path in setenv.sh. I remembered I tried this and the Jira Application didnt start. Seems like some of the paths are still using the jdk in the jira path. Not sure what went wrong.
Andy Heinzer
August 5, 2021
I am not sure what you mean by
You should not have to touch the setenv.sh file in order to make this work.
Try following the documentation guide for setting JAVA_HOME as explained in Jira Server: Installing Java:
On Linux
The JAVA_HOME environment variable is sometimes set in the /etc/environment file. You'll need to modify its value to JAVA_HOME="path/to/JAVA_HOME".
  1. If JAVA_HOME is not defined in this file, set it using the following command at a shell prompt, when logged in with 'root' level permissions:
    export JAVA_HOME="path/to/JAVA_HOME" >> /etc/environment
  2. Log out for these changes to apply.
Once that is done, log back into that session and try
echo $JAVA_HOME
to see what value is returned in the terminal.  If this is working as expected, then you should get back the path of your installed Java version.  If the path is correct, then try to start Jira.
jy August 6, 2021 edited
so can you tell me what ver is supported
I have done yum install java-11-openjdk-devel
After that I did as what you did, I added the
export JAVA_HOME="/usr/bin/java" >>/etc/environment
Then I stop-jira.sh and start-jira.sh
Then when I start jira
It is using JRE_HOME=/opt/atlassian/jira/jre
how do you know that atlassian jira is using the jdk that you use and not the inbuilt jdk?
Note that I used the bin installation not the tar.gz installation way to install.
Andy Heinzer
August 6, 2021
So the bin installer for linux, and the exe installer for windows will bundle Java when Jira is installed.  But the other install packages such as the .zip or .tar.gz do not do this.  Thanks for letting me know that part.  It is possible that your setenv.sh might have a JRE_HOME parameter defined there.   If it does, just comment out that line with a # at the beginning of that line and save that file.
But the JAVA_HOME parameter is not defined in the setenv.sh file in my experience.  Provided that a JAVA_HOME is defined the way we expect in this environment, Jira will use that when starting up if JRE_HOME is not defined.  You can also use a terminal command such as
which java
to see which path of Java is called by that user.
In regards to what versions of Java are supported in Jira, please see our supported platforms page.  At least in the current version of Jira 8.18.1, Java 8 and 11 are supported from either Oracle or the OpenJDK distributions.
jy August 7, 2021
I am using a lInux bin installer
Just comment out JRE_HOME in the setenv.sh? Then, I restart the server and it will work?
I remembered I tried this before, the tomcat failed to start properly.
Then it will use the JAVA_HOME environment variable defined in /etc/environment?
Yes , I am using OpenJDK11 as seen below:
jy August 7, 2021
Please suggest which method should I proceed with
1. Uninstall the existing jira software and use the tar gz method to install the jira software since the bin method just not recognize the JRE_HOME
2. Change some JRE_HOME environment variable in setenv.sh in Jira software.
Please let us know which is more preferred.
Andy Heinzer
August 16, 2021
Personally, I would comment out the line that sets the JRE_HOME if found in that file.  Provided the JAVA_HOME is set correctly, Jira will default to use that when JRE_HOME is not defined.
Alternatively, you can create a fresh install using a tar.gz install package, but I can't say which is preferable in all cases.
jy August 18, 2021 edited
there's no JRE_HOME in setenv.sh
I commented JAVA_HOME in setenv.sh
/opt/atlassian/jira/bin/check-java.sh line:31 [:-ne:unary operator expected
/opt/atlassian/jira/bin/set-gc-params.sh line:5 [:-ge :unary operator expected
Tried changing JAVA_HOME =/bin/java in setenv.sh , still the above same result
I won't want to go the fresh install route
If the bin installer is there, I am not sure why they "force" the user to use the in built atlassian JRE and dont allow the user to use the java installed in their own environmet
check-java.sh
line 31:
if [ $java_version -ne 8]  && [ $java_version -ne 11]
I am using:
OpenJDK Runtime Environment 18.9 (build 11.0.12+7-LTS)
OpenJDK 64-Bit Server VM 18.9 (build 11.0.12+7-LTS, mixed mode, sharing)
if you can help me to resolve this unary operator issue, and Jira application can run using the yum install openjdk successfully using the in built java for  Jira bin environment, I will straightaway mark this as solved.
Andy Heinzer
August 18, 2021
That error of
is a pretty clear indicator that the JAVA_HOME is not set correctly here.  JAVA_HOME is not expected to be set in the setenv.sh file, as I have tried to explain previously.  It is expected to be a system variable.  You should be able to run a terminal command such as
echo $JAVA_HOME
and then see the expected path in which your desired Java exists.  What value do you see when running that command?
Have you completed the instructions for setting the JAVA_HOME as found in https://confluence.atlassian.com/adminjiraserver/installing-java-938846828.html ?
On Linux
Please try this and let me know the results.
Andy
Yes , I tried this with root permissions.
echo $JAVA_HOME
/bin/java
In the setenv.sh, I should comment out JAVA_HOME and not set the env there?
In the setenv.sh it specifically said do not comment out JAVA_HOME
I remember I set the JAVA_HOME environment variable there and it get the unary operator error.
I have done all the above, if you have used a bin installation , you can try to set the JAVA_HOME both in the environment and in the setenv.sh, you should be able to simulate the unary operator error, if you tried to use any Java other than the atlassian jre
jy September 3, 2021
Jira software 8.19 seems to have upgraded their inbuilt JRE.
I will try using the 8.19 bin file to upgrade the existing installation to check if it has resolved the issue.
https://confluence.atlassian.com/jirasoftware/jira-software-8-19-x-upgrade-notes-1082527584.html
jy September 9, 2021 edited
Used the Jira software 8.19 bin file to upgrade existing,and run using its default JRE.
These are the vulnerabilities found:
- Apache Tomcat vulnerability
The version installed is 8.5.65 has HTTP transfer encoding request header vulnerability (CVE-2021-33037)
Recommendation: Upgrade Apache Tomcat to 8.5.68, where vulnerability is fixed.
SERVER
VERSION
8.17
