I recently upgraded to Jira 7.7.1 and Jira was working normally. I am able to start Jira but the application doesn't respond via the url I have configured (via a proxy through apache) or via the host name and port.
Looking at the logs, I have resolved all errors except one:
2018-02-28 03:32:05,447 HealthCheck:thread-1 ERROR ServiceRunner [c.a.t.j.healthcheck.support.GadgetFeedUrlHealthCheck] An error occurred when performing the Gadget feed URL healthcheck
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
at java.net.SocketInputStream.read(SocketInputStream.java:170)
at java.net.SocketInputStream.read(SocketInputStream.java:141)
at org.apache.http.impl.io.SessionInputBufferImpl.streamRead(SessionInputBufferImpl.java:139)
at org.apache.http.impl.io.SessionInputBufferImpl.fillBuffer(SessionInputBufferImpl.java:155)
at org.apache.http.impl.io.SessionInputBufferImpl.readLine(SessionInputBufferImpl.java:284)
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:138)
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:56)
at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:261)
at org.apache.http.impl.DefaultBHttpClientConnection.receiveResponseHeader(DefaultBHttpClientConnection.java:165)
at org.apache.http.impl.conn.CPoolProxy.receiveResponseHeader(CPoolProxy.java:165)
at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:272)
at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:124)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:272)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:56)
at com.atlassian.troubleshooting.jira.healthcheck.support.GadgetFeedUrlHealthCheck.check(GadgetFeedUrlHealthCheck.java:56)
at com.atlassian.troubleshooting.healthcheck.impl.PluginSuppliedSupportHealthCheck.check(PluginSuppliedSupportHealthCheck.java:49)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
2018-02-28 03:32:05,522 Caesium-1-3 DEBUG ServiceRunner [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.atlassian.troubleshooting.plugin-jira]
At this point I don't know what to do to get Jira back up and running. Any help would be appreciated.
The stack trace is basically telling you that jira is unable to contact itself.
Was it accessible after the upgrade?What did you change recently ? since the last working condition?
Check your proxy configuration.
Restart the apache service e.g sudo service apache2 restart.
Learn more
