Jira upgrade 7.10.1 to 7.13.3
chandler June 14, 2019
Hi Atlassian Team,
   We have upgraded the Jira server from 7.10.1 to 7.13.3. our server could not communicate with the Atlassian
 - downloaded the Jira Software and moved it to the server
 - Disabled Plugins that need update / unkown.
- Re indexed
- Performed health checks  (No issues)
- disabled the notifications
- upgraded applications using the Jira installer.
During the Upgrade we have forcibly stopped the Jira service .
After the upgrade the Atlassian Jira Service does not show up in the Windows services. Did any one come across such issue ?
Thank you.
brbojorque
Since this is a Windows environment.
You can reinstall the Jira service in services.msc.
cd <install directorty>/bin/
service.bat install Jira
After that it should show in services.msc and you need to adjust it to Automatic every time the server restart it will start Jira.
https://confluence.atlassian.com/adminjiraserver/running-jira-applications-as-a-awindows-service-938847902.html
Raj June 25, 2019
Thank you Bryan.
Tinker Fadoua
@chandler
Did you update server.xml file? Context_path and ports if you changed ports numbers from 8080
I assume that no changes were made to the DB, if no you will need to make changes to DBconfig.xml
Best,
Fadoua
Raj June 25, 2019
Hi Fadoua,
  Thank you for replying . The server.xml file was updated, since I was not sure what caused the problem reverted the server settings and the Database settings back and tried . Dint have problems this time.
Chand.
Register now
