we tried upgrading JIRA Core and Software from version 7.2 to 7.3 bit it went wrong. After hours of trying to recover configuration we decided to do a roll-back.
We did an unzip of the backup and replaced the /opt/atlassian/jira/ directory and installed database backup. After that JIRA start was fine and all plugins worked except JIRA software.
JIRA shows the error (Applications -> Versions and Licences):
Hi Nic.
We did like you said. Still doesnt work. It installes JIRA Software, but then all our Boards are gone. Probably many other settings too. We again needed to restore everything. Can you find something in the logs?
Logs: https://www.dropbox.com/s/wvqubpkubhi0y8m/atlassian-jira.log.1__?dl=1
FYI: I removed the board link
Thank you very much for your help
Regards, Ahmet
Don't use the add-on manager, it isn't an add-on. Use the Application manager.
I would suggest removing it completely, restarting JIRA and then adding it again, reading the logs during the download and install process for errors.
