Fixed in KFC Pro 1.0.4/1.1.2. Expect the release today.
Unfortunatelly we are installed JIRA 6.4.11 and we can't migrate to JIRA 7. Do you plan to solve this bug for a kepler-pro version compatible with JIRA 6.4?
It is already fixed. Check version 1.0.4.
Hi Begoña,
It seems, indeed, to be a problem. As far as we investigated it, it only appears when the Minimum characters is set to 0. Until we find a fix for this, you can set it to 1 as an workaround.
Hope this helps,
Alexandra
