How can I specify a default value? I'm using KCF - Autocomplete Multiple custom field type w/ option type of Issue. When I attempt to specify a default value, I get an error message:
Expecting object found: "DO-2096"
I've attempted to use: Issue key, Issue ID, Issue summary
How can I specify an object when setting a default value? I don't see a way for this to use an SIL script.
Hi Andrew,
The options are of KPOption type, so they must contain a label and a value. Try to set the field to something like this:
{"value":"10001","label":""}The 10001 value from above is the issue id.
The default value should get automatically converted to something like this:
{"option":{"label":"","value":"10001"},"meta":{"shortLabel":"TST-2","iconUrl":"/images/icons/issuetypes/bug.png","longLabel":"TST-2 - tw","labelOverride":"TST-2","href":"http://localhost:6260/browse/TST-2","tooltip":"tw"}}
Hope this helps,
Alexandra
You're right, this wasn't contained in the documentation. I have just created a new page regarding it: https://confluence.kepler-rominfo.com/display/KCFPRO/Example+5%3A+Setting+default+values+for+KCF+Pro+fields Thank you for your suggestion. :)
