Kanban Backlog - feedback for Atlassian
Wade Harshman
Just wanted to let the folks at Atlassian know that one of their feedback forms didn't work.
When I disabled the Kanban backlog, a feedback form came up asking why I had done that.  I filled it out, but it wouldn't submit.  I tried twice.
For what it's worth, the reason I disabled the Kanban backlog is that when it's enabled, all issues on the board disappear, regardless of their status.  When I disable the backlog, the board works as expected.
Brant Schroeder
August 23, 2023
@Wade Harshman I will escalate this to Atlassian so they can take a look at it.  Since you are on Server your firewall might be blocking the feedback form from posting.  You should check and make sure that is not the case.
