Kanban Board have to remove under a single project
Roja Gurram
Hi ALL,
Under single project  we have a multiple kanban boards now i wanted to remove/delete one kanban board so, the change will reflects to only one board ( what i want to delete) or any other boards under that project ?
Your help would be hugely appreciated!
Andrew Morin
July 2, 2020
Not real clear on what you are asking but I think you are asking if you can delete the other kanban boards that are pulling issues in from a single project or are showing up when you click the icon that shows the boards in the project.
So scrum/kanban boards only store the board configuration. So if you are the board owner or administrator in your Jira instance instance depending on which version you are on go to the Boards drop-down and select Manage Boards. Once there find the board you want to remove. once you see it click on the three dots on the right.
If you are on the new UI...
  • click magnifying glass upper left sidebar
  • scroll down to boards section and click view all boards
  • find your board in the list and click ellipses on far right select delete
Roja Gurram
Hi Andrew,
Deleting a board is fine. Thanks for that.
My question is if  we want to delete  one kanban board  out of 10 kanban boards under a single project is there anything will damage to the project ?
Andrew Morin
July 2, 2020
No it will not.
Roja Gurram
Hi Andrew,
Thanks for the update and clarification.
Mariana_Pryshliak_SaaSJet
July 2, 2020
Hello  Roja_Gurram.
To delete a Kanban board you need to
1. Navigate to Programs > Kanban Boards;
2. Click on the board you want to remove on the Kanban Boards page
3. Click the Delete link on the board's slide-out panel.
I don't know exactly whether the changes will reflect only one board. So you can ask this in the community in another discussion
Also, you can check answers on this link: https://community.atlassian.com/t5/Jira-Core-questions/How-can-i-delete-a-kanban-board/qaq-p/348674
or a Youtube video guide:
https://www.youtube.com/watch?v=9-N8nH9iMnE
Best regards, Mariana.
Roja Gurram
Hi Mariana,
Thanks for the response.
