I am creating an issue form for a new project for our client.
I need to know if it is possible to show button of the "issue forms" in the main interface instead of "Create" button or at least a shortcut in the main interface. See the image attached
Otherwise, if it is not possible, once that I have created the issue form I want to be opened by the create button on the main interface from the user. Is it possible?
@Armand as others have noted you can neither place Issue Forms in the top bar nor alter the Create Button button contents; however, you might find the direct link to an issue form useful.
You can add the direct link as an option in Jira Project's navigation sidebar. In this example we link directly to our Bug Report form. To add your own link click Add Item from the project sider bar.
It's not the same as having it in the top bar; however, a lot of customers have found it useful.
Hi @Armand welcome to the Atlassian community.
To my knowledge, please be informed that, the UI will not permit to place app beside nor replace "create button".
If their is such an option you heard about, then I would request you to check with Atlassian support team for any documentation.
Stay safe and stay healthy.
This is not possible out of the box. You might check the marketplace for potential add on apps.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
