×Hello there,
I'm facing something strange, I've created and configured a Kanban board but it looks like is not showing all issues, for instance, DEV column say 0 of 10 and DONE column says 1 of 65...
Looking at the filter query used for that board...it basically returns all my issues
Looking at my column config, it gives the correct number of issues per column and status:
I've tried to re-index and change kanban sub-filter as suggested here:
To no avail....why I'm doing wrong?
THanks!
Geez....I've found what is was...I had quick filters applied! D'oh!
You have to include the closed status under any one of available column to see all issues.
Hello @Mahendran seriously? What if I remove CLOSED from my current worflow...which is my case...do I have to artificially include that status in a column and then remove it with the filter?
Anyway, tried this and I can't see issues in DEV column anyway...
