Where is the Kanban backlog in JIRA Core?
Where can I go in Jira Core to start a simple project that operates with a backlog and with columns as explained by Eric Brechner?
I can make a workflow (but honestly - as I pay for this JIra I did expect it to be available in the system) but anyway it would be good if project management had "backlog"...
Maybe it does and I just need to find the right menu-button?
Hi Jan,
You should be able to click on the Projects menu option at the top and then select Create project.
Core doesn't have kanban boards, it does project boards, where the columns are determined by the workflow.
