Hello dear community,
I would like to present on the Kanban board swimlanes per task (even if the task do not have sub-tasks). I tried "Stories" swimlane but this throws automatically all the tasks without sub-tasks to one bucket and what i really want to achieve is to have a separate swimlane for each task with sub-tasks (or not) grouped.
Is there any simple way of doing that other than listing up all the tasks?
Thanks a lot!
Aleksandra Tylko
Hi @Aleksandra Kakol ,
unfortunately you can't do that. If you use swimlanes like stories (on scrum board because on kanban you can group just for None, Assignee and Subtask ), all ticket without subtasks will be presented as a single card.
It seems correct because, otherwise, you can't easily understand in which is the current status associated to the ticket.
Scrum board with swimlanes as Stories
Kanban board with group by Subtask
Hope this helps,
Fabio
thanks a lot for your quick reply!
Pity that is not possible :(
Aleksandra
