LDAP User Filter
IT ADVITOS May 23, 2018
on my server instance I want to configure a user filter, but I get the error shown below.
What I want to do works for confluence user fitlers.
Here is the filter I want to apply:
(&(objectCategory=person)(sAMAccountName=*)(|(memberOf=CN=AUG AJI Users,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)
(memberOf=CN=AUG AJI System Admins,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)
(memberOf=CN=AUG AJI Service Desk,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)
(memberOf=CN=AUG AJI Admins,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)
(memberOf=CN=AUG ABA Users,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)
(memberOf=CN=AUG ABA System Admins,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)
(memberOf=CN=AUG ABA Creators,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)))
Result is the given error.
The following filter is working;
(&(objectCategory=person)(sAMAccountName=*)(|(memberOf=CN=AUG AJI Users,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)))
Basically every OR seperated value is working in singular. But if i concatenate two of them I get the error.
For my confluence settings a similar filter is just working fine:
(&(objectCategory=person)(sAMAccountName=*)(|(memberOf=CN=AUG ACO Users,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)
(memberOf=CN=AUG ACO System Admins,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)
(memberOf=CN=AUG ACO Space Admins,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)
(memberOf=CN=AUG ACO Admins,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)))
Error:
Technical details
Log's referral number: 1c381f37-b5c0-41f2-beb7-05409b85e894
Cause
Referer URL: https://jira.hepawash.com/plugins/servlet/embedded-crowd/configure/ldap/?directoryId=10000&xsrfTokenName=atl_token&xsrfTokenValue=f1860613399ea12fd25e1909114ec3b58406024e
Request processing failed; nested exception is com.atlassian.jira.exception.DataAccessException: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:DirectoryAttribute][name,ldap.user.filter][directoryId,10000][value,(&(objectCategory=person)(sAMAccountName=*)(|(memberOf=CN=AUG AJI Users,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)(memberOf=CN=AUG ABA Creators,OU=Development Services,OU=Application Usage,OU=Groups,OU=Company,DC=HepaWash,DC=loc)))] (SQL Exception while executing the following:INSERT INTO dbo.cwd_directory_attribute (directory_id, attribute_name, attribute_value) VALUES (?, ?, ?) (Data truncation))
Andy Heinzer
May 23, 2018
Hi @IT ADVITOS
This is unfortunately a known bug in Jira.  There is a limitation on the length of the database field that stores your LDAP filter.  You can read more on this bug in https://jira.atlassian.com/browse/JRASERVER-36979
In short, Jira is only able to store LDAP filters natively that are 256 characters or less.  From looking at your first filter, it's 864 characters, and your second is 514 characters.   However there is a work-around for this.  Please see the KB: Data truncation due to data too long for column
In the examples there, they explain how you can run these SQL commands to extend that size of that field to 400 characters, but obviously in your case, you are probably going to want to expand it to at least 900 characters in order to accommodate these filters you have.
I would recommend that you stop Jira before you try this, AND that you take a backup of your Jira database before making these changes.   If you're using postgresql for the Jira database, you could then try to change the database fields with the following commands:
alter table cwd_group alter column description type varchar (900);
alter table cwd_group alter column lower_description type varchar (900);
alter table cwd_directory_attribute alter column attribute_value type varchar (900);
The syntax might be different for other database types such as mysql, ms sql, or oracle.
Please let me know if you have any questions or concerns about this.
Andy
