Hi
I have created some lables in JIRA but I can't find them except I click on a ticket with the label.
Please any guides on how I can find all my created labels in a list. I need it to pull reports. Thanks
For a list of labels per project, use the label gadget. To view all labels, either use the REST API https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-labels/#api-rest-api-3-label-get or go to https://yourdomain.atlassian.net/rest/api/3/label on your browser.
I'm not sure of a way to do it across the entire Jira instance, but Jira DC has a Labels gadget that you can put on a dashboard. You have to specify a single project and it will show you all of the labels associated with that project.
Hi @Ri A
Using Colored Label Manager you can :
Visualize your labels with at-a-glance quickness to save time and avoid mistake - Make your issues more colorful
Allow your team to define their labels, cleanup and organize them quickly with bulk powerful functionality .
Karim
Atlassway Team
