I'm trying to setup label inheritance on my tasks.
For a single label, it works wonder :
But when my Epic has multiple Labels is doesn't work, I'll get "Label1, Label2" and 2 issues :
it tries to create a single label instead of 2 seperate labels.
even that fails, as there is a space (The label 'Label1, Label2' can't contain spaces. (labels))
If I translate that in some simple code I'd need :
foreach label in issue.Epic Link.Labels
issue.Labels.add(label)
But how can I do that in Jira Automation ?
Remark : I'm not sure if it is possible to set my issue Label equals to my Epic Labels, but that's not what I'm trying to do, as my users should be able to set new labels specific to their issue that are not present in the Epic.
Why smart value when you have option of copying it directly from Parent issue
Let me know if it works
Pramodh
That's perfect didn't see the option :)
Still interrested in knowing of to make a foreach work in Jira Automation as I'm sure I'll need it someday but this solve my question ;)
We would need advanced option when we need to copy multiple values for the same field.
I will explore on the same and post it here 🙂
