Sign up Log in
Left nav bar missing
Deleted user May 30, 2024
HI all,
I've been tinkering with Jira (we used to work on it for work but now I want to use it for personal projects) however, I've run into an issue that I haven't seen before.
Whenever I load a Software/Sprint project (created from a template) from the home page, it loads the left navigation panel correctly, however, if I reload the page in place, the left nav menu doesn't load and all I see is the loading skeleton as seen here:
Is there any associated issue for that? I already tried using incognito window, disabling all extensions, clearing cookies and tried in other browsers (Firefox and Safari) but the issue is still there no matter how much I reload.
Another associated issue is the theme, I work in Dark mode but when I reload, the issue appears and the theme is set back to Light mode.
Andy Heinzer
June 3, 2024
Hi @[deleted]
I am not seeing any clear cause from our side here.  So I created a support case for you in https://getsupport.atlassian.com/servicedesk/customer/portal/23/JST-1006080
I suspect that our team might request of you data access to the site, to check for themselves, or perhaps a HAR file to see if we can better understand what might be causing this problem in your environment.
Deleted user June 4, 2024
Thanks for picking this up!
Like John Funk likes this
John Funk
May 31, 2024
Hi Sebastian - Welcome to the Atlassian Community!
I suggest you contact Atlassian Support. I would suspect it's a browser issue, but you have been through those checks.
https://support.atlassian.com/contact/#/
Please post back here with the resolution for future readers.
Upcoming Jira Events
