License management Jira Work management?
Malin Rathjen
Hi Atlassian community,
my company is considering to use Jira Work management for projects from HR and marketing. We are right now using Jira Software on Premium plan for 400 Users. My question to ask is: would we need to buy Jira work management also for 400 Users or is it separated from the other Atlassian softwares, so that we could only buy 50 licenses for example.
I appreciate your help! Thanks a lot!
John Funk
Hi Malin - Nope, you don't need to buy more licenses - you can start using it right now!
Malin Rathjen
Hi John, thanks for your quick answer! So do I understood you correctly that with Jira Cloud Premium we can use Jira Work Management for free for all 400 users?
John Funk
Yes!  :-)
Give it a try and see - just create a quick project and had a test issue or two.
Malin Rathjen
Ah yes, I see that it works :) Thanks for your help!
John Funk
Wonderful!
Register today
