Link Text in a Custom Field
Andrew Willy May 6, 2022
Hello!
I would like to use link text in a custom URL field.
For example, the link would like this:
Order
But it would open this:
https://www.atlassian.com
I understand this fundamental behavior for URLs but I can't figure out with these custom fields. Help appreciated!
Andrew
Ste Wright
Hi @Andrew Willy
As far as I know, you can't do this in the URL Field - it just displays a URL.
If you want to hyperlink text to a web link, you need to use a Paragraph custom field - which supports rich text, allowing you to do this.
There's a good description for how this works on this Feature Request: JRACLOUD-69877
Ste
Andrew Willy May 9, 2022
Thank you!
Like • Ste Wright likes this
Abhinav Srivastava
Hi @Andrew Willy
I want to achieve the same functionality, were you able to achieve it yes, then could you please share how did you achieve it?
Andrew Willy June 14, 2022
We ended up leaving the URL displayed as URL.
Like • 2 people like this
Yugandhar Mocherla September 28, 2023
We used a paragraph custom field for link but it is rendering as a link half of the text due to space between the words. How can we solve this issue.
Yugandhar.
Ste Wright
How have you setup the field / link?
A screenshot could be beneficial here.
Ste
Register now
