Hi Team,
We are trying to create a known issue register and want to be able to see the total number of linked issues for each issue e.g. each product team has their own Jira board which they will create am issue in for each bug. They will then link any incidents raised via our service desk to that bug. We need a quick way to see the total number of linked issues.
I have trawled through the community pages and seen lots of similar questions but they are never exactly what we are after so don't pull the right results. This is the automation I have tried so far and it works perfetcly when I link the first issue, but then never updates past "1" when I link further issues.
What am I doing wrong here? I have also tried {{destinationIssue}} instead of {{issue}}
Hello @Mia Bright
Where do you want this linked issue count to get updated? In the Bug?
If so, your workflow context is important on how you set up the rule.
So for that, you need to be clear on how are users linking these issues.
You have scenario 1 set up.
I am sharing how to set up scenario 2 in below screenshot.
You should have both these 2 rules to complete your requirement.
Also, good practice to log as much as you can so you can follow along your progress.
Hope it helps.
Thanks for your reply, I am wanting the count to display on the bug in a newly created field called "linked issue count" and I need the issues to be able to be linked from either the bug or the incident.
Please implement another rule like i have in my screenshot. Together, the 2 rules (one you earlier authored and the new one) will complete your requirement.
Please let me know if issues, do share screenshot of audit log so we can see whats the issue.
I have added the second rule as advised
However it doesn't appear the branch is working. When I try to link from the incident to the bug I get the following in the audit log, no issue count.
If I link from the bug to the incident it doesn't run at all.
Hello, looks like your issues are in different projects.
You need to include the scope of both projects in your rule details you are authoring. Please see if you have permissions to add / increase the scope.
Hi yes sorry I did mention in the original post that the bugs would be in the product team's boards and the incidents would be in our service desk. I'm not sure what you mean by check if I have permission to increase the scope? I am an admin and have permissions to do everything.
Sorry never mind, I have added the two projects together in the scope. Working now, thank you.
Great to hear, please consider accepting the answer so it can benefit others in the future. Thanks!
@Kalyan Sattaluri
Hey, what should I put in the edit field in the first formula check SS?
Can you verify the solution check video https://www.loom.com/share/d180900f3f43410983d08e94616e013e
@Petar Cvetanovic You can use {{#increment}}{{Total Assets}}{{/}} if you want the number be updated every time a link is made.
Hi @Mia Bright
I'm glad to see you got this to work using Automation.
Just for future reference, if you're open to solutions from the Atlassian Marketplace, I think you might like the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of so-called smart columns that aren’t natively available, including the number of issue links, along with many other issue-link-related columns.
This is how it looks in action:
As you can see above, you can easily sort and filter by your smart columns, and also use them across JXL's advanced features, such as support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting.
This all just works - there's no automation or scripting whatsoever required.
Best,
Hannes
Hello @Mia Bright
What is in the Audit Log for the rule execution when you link the second and later issues?
What are the details of the Edit action?
In the second and later link creations, from which issue are you initiating the link creation; the Bug or the Service issue?
