Local Jira Gurus or contacts
Jacqueline La Grand June 4, 2019
I am looking for an local knowledgeable Jira users in the Hamilton, Waikato NZ area that would be able to assist with a project we are currently undertaking.
2 accepted
Gonchik Tsymzhitov
Hi @Jacqueline La Grand !
You can try to find in partners the some guru
https://partnerdirectory.atlassian.com/
or Linkedin.com
I would say It's your time to be a guru :)
1. Setup the event https://aug.atlassian.com/
2. learn here
3. pass the certificates
I hope it helps
Gonchik Tsymzhitov
Kat Warner
Good luck with your hunt for local help.
There is an NZ-wide Slack group you can join here.
Register now
