I connected to JIRA via SQL and created a query. I created a Custom Field in my tickets named REPORTED BY, and I can find the numeric value, but I cannot find the Alpha data which would be a persons name. Any idea where I could find that data within the DB?
@Michael J. Schneider See if this documentation provides you the required user information from JIRA database: https://confluence.atlassian.com/jirakb/how-to-extract-user-data-from-external-database-table-699957597.html
@Michael J. Schneider Did my answer helped resolving your query?
We are working on it. I should know by tomorrow if it worked.
Taranjeet
My SQL admin was able to find the "Custom Field_Reported By" field that I set up, but it only brings back numeric values. He checked the JIRA Schema pdf and was not able to find it. That is the last field we need for what we are doing.
let
Source = Sql.Databases("JCSQL55"),
JiraDB = Source{[Name="JiraDB"]}[Data],
dbo_vw_JiraIssue = JiraDB{[Schema="dbo",Item="vw_JiraIssue"]}[Data]
in
dbo_vw_JiraIssue
The question is related to the portion where we determine the ReportedBy custom field.
SELECT PR.pkey + '-' + convert(varchar, i.issuenum) AS IssueKey
, PR.pkey as ProjectKey
,i.SUMMARY
--,CG.ID as IssueId
,it.pname AS IssueType
,ISs.pname AS IssueStatus
,P.Pname AS Priority
,i.CREATOR as Creator
,i.DESCRIPTION
SELECT STRINGVALUE
FROM customfieldvalue
WHERE CUSTOMFIELD = 10108 -- HysolateTicket
AND ISSUE = i.ID
) AS CustomField_HysolateTicket
,i.CREATED
,i.UPDATED
select DATEVALUE
from customfieldvalue
where CUSTOMFIELD = 10601 -- Closed Date
and ISSUE = i.ID
) AS Closed_Date
SELECT top 1 STRINGVALUE -- Pending match to the personName
WHERE CUSTOMFIELD = 10204 -- ReporteBY
AND ISSUE = i.ID
) AS CustomField_Reportedby
FROM jiraissue I WITH (NOLOCK)
INNER JOIN [issuetype] IT ON I.issuetype = it.id
INNER JOIN issuestatus ISs ON i.issuestatus = ISs.id
INNER JOIN priority P ON P.id = I.PRIORITY
INNER JOIN PROJECT PR WITH (NOLOCK) ON PR.ID = I.PROJECT
Any idea where the information in this Custom Field "Reported By" would be located? I created it because the CREATOR field isn't always the person who reported it.
@Michael J. Schneider You can extract that information from app_user table in the JIRA database, I think. You may need to use JOINS with app_user table to extract this user information for your issues. See the link for the documentation I provided for more information on what information you can get from app_user table.
