Dear community,
After setting up a JIRA integration with our self hosted Gitlab instance we get the following error:
Client authentication failed due to unknown client, no client authentication included, or unsupported authentication method.
Followed all steps in this guide. Installation is succesfull.
In Jira Cloud go to "Apps --> Manage your Apps --> GitLab for Jira (gitlab.example.com) --> Get started" resulting in this page:
After clicking the "Sign in to GitLab"-Button this error is displayed:
Any hints what might be the issue and what we can try to get it solved?
Hello Paulvn
Welcome to our community :)
Did you notice this note in the documentation
On self-managed GitLab, by default this feature is not available. To make it available, ask an administrator to enable the feature flags named jira_connect_oauth and jira_connect_oauth_self_managed. On GitLab.com, this feature is not available. The feature is not ready for production use.
It appears:
I suggest you reach out to GitLab for clarification and configuration assistance.
Hope that information is helpful.
Hi Ligia,
Thanks for the response.
I looked into it again. This feature was released some time ago, and is no longer behind a feature flag. The documentation link refers to an older version of Gitlab.
I will look into proxy settings again / check with Gitlab
Hey paulvn
Thank you for the information, I was not aware of that change in GitLab.
If there is something needed from the Jira end, just message this thread and hope we can find it together.
Thank you
