Look for epics, which contains stories which are under a specific relase
Attila Szőke
April 27, 2022
Is it possible to create with default JQL a filter, which can list out every epics whose stories are under a specific release?
Let's say an epic's stories can be under different releases (Fix versions), and I'd like to see those epics, which is assigned for a release (but the epics doesn't have versions, only the stories and tasks under it)
Ste Wright
May 7, 2022 edited
Hi @Attila Szőke
Not natively - you'll need an App which expands the JQL function options - such as Scriptrunner
Then you could use sub-querying - for example...
issueFunction in epicsOf("issuetype = Story and fixVersion = 'Version 1'")
^ The text in the brackets is the sub-query - it's looking for Stories with certain parameters.
Ste
Attila Szőke
May 15, 2022
Hi @Ste Wright
Thanks for the help, Scriptrunner is available and this works :)
Attila
Like Ste Wright likes this
