Looking for CLEAR direction on Sigma fields.
Christa Meck April 9, 2024
Jira Cloud Premium.  I have Admin Admin permissions in our instance and all roles assigned in the project that I am using for my test.
The Sigma fields are just completely baffling me.  I've taken a lot of time researching this and am unable to find a comprehensive guide on these fields.
Here are the fields in question:
  • Σ Original Estimate
  • Σ Progress
  • Σ Remaining Estimate
  • ΣTime Spent
For the sake of simplification, let's just focus on Σ Original Estimate because that is the one I care about at the moment.
I believe the following statements are TRUE:
  • The sigma fields are created by Jira when Time Tracking is enabled AND Sub-Tasks are enabled.
  • The sigma fields can be added to cards so the data is visible when you are looking at a board.
  • The sigma fields are most visible and most powerful in the Time Tracking Report.
  • The sigma fields have absolutely nothing to do with any parent/child relationship UNLESS you involve Sub-Tasks.  Meaning: These fields won't do sums for Epics.
Now that you have an idea of how much I've looked in to this...  I would like to know why on earth I can not get these sigma fields to display in Description, Details, More Fields or really anywhere on the individual issue view screen.
TL;DR: I would like Σ Original Estimate to appear anywhere somewhere on the issue view screen and I can't figure out how to make it happen.
Thanks y'all.
- Christa
Ste Wright
April 9, 2024 edited
Hi @Christa Meck
I've tested this, in a Company-managed Project, and...
  • Hours are aggregating to story-level (from sub-task)
  • I can use the field in issue search results
  • I can view the field data on a board, when added to "card layout"
As far as I know, these aren't "fields", they're calculated in the background. So you can't add them to a Screen.
You can see an aggregated view of time tracking (i.e time spent) on a story by checking the box "include subtasks" next to the field though?
The alternative is to aggregate the data into the Original Estimate field using Automation - i.e...
  • Set Original Estimate at sub-task level
  • Roll/sum these values into the field at Story-level
  • Continue to roll it up to higher levels if needed
Let us know if you need help on how to do this :)
Ste
OK Cool.  Silly that I have a field I can put on a card and view in search but not apply to a screen.  Oh well #AtlassianLife amirite?
Thanks.
- Christa
Like Ste Wright likes this
